TMPGEnc Video Mastering Works Update
  • TMPGEnc Video Mastering Works Update
    Looks like it was just updated to 7.0.20.22 today.
    just a quick question... TMPGEnc Video Mastering Works 7..... can it play HQX files?
    edit: 4k HQX files
      It can do much more than play the HQX files. The screen shot is of the timeline mode.
        HI Jerry.. I know what it can do, but on my system It will not play 4K HQX files. I am still using E7 and win 7 pc.
        From your screen shot the text clip is HD. can you try a 4k HQX clip?
        the test clip I created was HQX 10bit .. not sure if it was 4:2:2 .
        It did play Canopus lossless 4:2:2 8bit test clip.
          I am unable to make a UHD 10bit HQX file in EDIUS 9 or X even though when I view clip properties of the exported clip in the bin, it says it is 10bit
          but mediainfo and TMW7 see the clip as 8bit and the clip works fine in TMW7
