New Blue Titler 7 Not Rendering
    Hi Anton -
    Thanks for your help. Looks like below (the files are actually in six sub-directories. I used a file manager to make the screen capture below, which makes them appear like they are all in one shared directory).
    The "Titler" subdirectory contains the file named "EdiusXHostDC" listed below.
      that looks fine, except I don't use OFX Bridge
      can you make sure EDIUS is closed and then delete both OFX entries and try the tilter again
      if no improvement, restore the OFX plugins
        Originally posted by SeanW View Post
        I created the simplest possible timeline in 1080p60, and put the title sequence on a dedicated "T" track. Same story.
        This is not a "me" problem, this is a "them" problem. Their stuff doesn't work.
        Do me a favor and start a new 1920x1080 29.97p 8bit project. Place just a title on the timeline and let it render within the TP7 interface before returning to Edius.
        Does this play easier?
        You can also use the preview resolution dropdown to help in playback.
        Instead of using Shift+G on the title, let it render normally through the TP7 interface. You can try either a Shift+G or a Shift+Q on the video clip to render it instead of the title.
          I have tested by dropping resolution as low as 1/4 in a 1080 59.94p project and the buffer drops to 1 and then it stutters, even though the title is fully rendered inside the titler. Something not right for sure. It appears as if the EDIUS resolution dropdown bypasses Newblue titler
            You don't need to replace any graphics card!I use AMD RX5700 and gtx1050 rtx3080.Gpu,I have fed back this fault for some time, but it still hasn't been solved,The possibility of using English is much less, but once use Chinese subtitles are restarted EDIUS ,is basically offline,This software is not reliable!
            • #21
              Anton, I get real time 1080 59.94 10bit playback with NB Titles.
              the difference in my project settings is that I don't have Lanczos 3 selected. I also have my ram buffer setting at 8GB.
              • #22
                I get realtime on my main PC, I was testing this on my Office PC i7-4770 but it should be realtime since I render the title inside the titler. So what would be the point to render inside the titler?
                • #23
                  But, the main issue is also that the EDIUS resolution drop down does not help at all when it comes to Newblue Titler, not even at 1/16
