Acon Digital Limiter issue - Edius X
  • Acon Digital Limiter issue - Edius X
    I've been really impressed with the Acon Digital limiter that is bundled with Edius X, however I have noticed that when applied to more than one audio track in Edius it is disabled.
    Turning off the 2nd track re enables it but in my situation I wanted to apply it to two tracks. Is there a fix?
    I can't repeat it, I applied it to two clips that are on two tracks above one another and it works
    how is it disabled in your case? is it unticked in info palette?
    remember that you need to compensate for extra loudness by having two clips above one another so you need to increase the limit amount of each clip a bit like -8 instead of -6 etc.
      I’m not using Edius x yet, but it might also help to know if you are using VA tracks, stereo tracks or mono tracks so others can replicate the setup and help identify the problem.
      Edius WG 9.55.7303, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
        I tested with V+A and VA tracks and it works fine
          I can't replicate this either.
            Sorry a question, I didn't understand correctly, is Acon Digital free on all ediusx versions?
            That is Educational, Pro, WorkGroup version?
            Or for the Educational and paid version?
            thank you.
            Edius pro X -W10 pro -Lumix fz 1000-I7 10700 8 core-RAM 64 gb 2666 Mhz-GTX 1660 super 6 gb-GTX 960 4 gb-DJI Ronin-SC-
              just go to the EDIUS help menu and click the download Bonus software link, then download the ones you think you need and install them
                thank you.
