Pitch correction
  • Pitch correction
    Any suggestions for a pitch correction plug-in? If I need to speed up a 23.98fps interview to 25fps, I'd like to pitch correct on Edius timeline, rather than export the audio to Audacity or similar and then back. I know there is something labeled "pitch shift" in Edius audio effects, but it's not suitable for dialogue.
    Desktop: Edius 8.50 WG/Win 7 Pro/HP Z620/Intel Xeon E5-1620 @ 3.60GHz/16GB RAM/NVIDIA Quadro 4000/Storm 3G
    Laptop: 8.50 WG/Win 10 Home/ASUS ROG G751/Intel i7-4710HQ @ 2.50GHz/16GB RAM/NVIDIA GeForce GTX 970M
    you can use the built in pitch correction filter
      23.98 to 25 is on the verge of where most people start to hear a pitch shift (about a 4.27% speed change for that framerate conversion). Sometimes you can get away without the pitch correction and sometimes it is needed.
      I am not aware of a third party correction plugin for Edius but someone else may be. Whenever I have to do this I always use a separate audio program, as I also like to do the correct samplerate conversion using a high quality audio engine. Depending on where I am, home or office, and the number of track that need pitch correction, the program varies.
      Edius WG 9.55.7303, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
