Audio Noise Reduction plugin x Edius 8
    If you had X I would recommend Waves plugins. The NS1 is very good. Even the Avon plugins that come with Edius X is quite good at noise suppression.
    Yes Jerry I wish I had the money to upgrade... I hope soon ;)
    But doesn't Edius X have built-in audio filters?
    Maybe it could of some interest for Edius 8 users.
    I made some test with the new Izotope RX8 de noise. As I said I made this interview in a lab with several fridges on.
    I uploaded a 1 minute raw clip with higher volume. The first 30" with filter off. The following 30" with the filter on (default settings).
    Refrigerator humming is not gone but quite lower. I don't see voice degradation or audio delay.
    I'm a audio beginner, should I see a delay between lips and voice?
    Edius 8.53 WG on Intel i9-9900K, Fractal design Celsius S24, ASRock Z390 Taichi, 16GB Corsair Vengeance LPX DDR4, 3GHz, Corsair RM850x, 1x500GB + 1x2TB Samsung EVO, 10TB Toshiba HDD, MSI GTX 1660 6GB DDR5
      4 Acon filters are included with X that work quite well.
        Regarding audio and video sync, yes you will see a few frames out of sync when applying most third party audio effects. So you will have to move your audio by a few frames. That's another great upgrade in EDIUS X. Automatic audio latency correction that takes care of that problem. Works great.
