Audio Noise Reduction plugin x Edius 8
  • Audio Noise Reduction plugin x Edius 8
    Hi all,
    I have to clean several clips from a constant hum noise. I would like working inside Edius 8. Any suggestion for a simple but effective plugin?
    Thank you in advance
    Edius 8.53 WG on Intel i9-9900K, Fractal design Celsius S24, ASRock Z390 Taichi, 16GB Corsair Vengeance LPX DDR4, 3GHz, Corsair RM850x, 1x500GB + 1x2TB Samsung EVO, 10TB Toshiba HDD, MSI GTX 1660 6GB DDR5
    If you want to stay within edius I'd suggest the wave arts MR suite's MR Noise and/or MR Hum, but you can often get much better result using a proper audio software to spit shine your audio. You can purchase these plugins individually or as part of the MR suite. MR Hum will probably look after your problem, but having the other tools in the suite is not a bad thing either. https://wavearts.com
    It is also possible to notch out a specific hum with an EQ, but this can also sometimes require doing a comb type filer where you have to find the root frequency and then also create additional notches above at fixed octave or partial octave intervals.
    Edius WG 9.54.6706, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
      Thanks,
      I shot an interview in a lab full of refrigerators so I have a constant low frequency noise that Audacity is able to remove perfectly. I would like to stay within Edius trying to simplify my workflow.
      I'll look your suggested plugin
        Wavearts also has a dialogue 2 plugin I never tried it myself bit it may also work for you.
          Maybe IZotope RX Elements (De-hum) is a choise. There are 4 plugins altogether for $20.21 (Flash-Sale).
          Carsten
          Edius 9.54, iZotope Elements, TMPGEnc VMW 6, HandBrake 1.3.3, Blender 2.90.1, Red Giant MB Looks, Hitfilm Pro 16, Videocopilot E3d, Opitcal Flares
          i7 5820k, 32 Gb RAM,NH-U14S, MSI X99s SLI Plus, MSI GTX 1060, WIN 10 Pro 20H2 (SSD Samsung EVO 850), 3 HDD
          Panasonic FZ2000 V-Log
          TV Sony KD 55X8507C(4k HDR10/HLG), Player Sony UBP-X800 (UHD)
            Wow! Will it works with Edius 8.53WG?
              The Izotope stuff is great, but causes a fair bit of latency. Eduis 8 does not have the latency compensation in it that a DAW has to address this issue. That's why only some audio plugins work well in Edius versions prior to Edius X. Edius X has introduced latency compensation.
                That is good to know. Do you know if the RX8 Audio Editor has latency compensation?
                Carsten
                  I'm not a professional so the $20 flash offer was very tempting and I decided to give it a try.
                  In the technical specifications of the new RX8 version they write that the Voice De-noise plugin has zero latency.
                  https://www.izotope.com/en/products/...-de-noise.html
                  I tried it with one of my clips and with the default settings it takes out all the fridge noise apparently without degrading the vocals and with no latency.
                  So far I'm happy with it. I need to play with it a bit because I can't find a manual that explains the filter settings well and I'm a real beginner with audio.
                    The latency compensation is a feature of the host application when using plugins. Using the stand alone Izotope applications is fine. Latency compensation is to correct for the time delay to get audio out of the host software, through the plugin and back in to the host.
                      Interesting, I never used the RX8 stuff, but have used older versions and there was a latency issue.
                        Wavearts Master Restoration is the way to go in EDIUS8 as it causes 0.0000% delay after export
                        or you can upgrade to EDIUS X and have Noise Reduction built in
                          will that plug in work in edius 7?
                            Wavearts Master Restoration works in EDIUS 7
                              If you had X I would recommend Waves plugins. The NS1 is very good. Even the Avon plugins that come with Edius X is quite good at noise suppression.
