New Blue Titler 5 resolution issue
  • New Blue Titler 5 resolution issue
    I've moved from VisTitle to New Blue Titler 5 and whilst I like to look of the titles I've suddenly encountered a weird issue that sees the title float from high the low res and back to high even on a rendered clip. It only happens for a second or so here when the voice says "And Legends"
    Sample here https://youtu.be/9UCkh7yNRq4
    I will be updating to Edius 10 soon so any tips on better title programs are most welcome. I certainly don't want to go back to Vistitle. I find that program has a very dated look about its titles.
    UPDATE: It only has the problem when the title is animated. A normal still title is fine.
    I do agree the templates, not titles, are dated. I take it that you don't use a titling program to create but rather to just use templates. That's fine and
    dandy until you tire of the templates and are at the mercy of the titling program company to create more templates. This goes for both Vistitle and NB.
    Take a look at the templates in the video. I don't consider these Vistitle templates dated. Each title took around 10 minutes to create.
    I have created over 300 templates of titles and Smart elements for projects.
    I prefer the stability and creation options of Vistitle over even the full Titler Pro 7 Ultimate edition, which I own.
    https://we.tl/t-L1LPsnXJVT
      UPDATE: Thought issue was fixed by changing each title to a still title and then going back in an reactivating the animation on each one. However the issue soon returns.
      I've now tried my other PC, same issue.
      Perhaps the template I am using is currupt?
        What font are you using?
        Here is a reasonable facsimile of the lower 3rd that you used.
        Just change the font.
