Title Pro multi titles management
  • Title Pro multi titles management
    Hi, I can't figure out how to work with multi titles, I saw that there is a title list but in the edius version I can't find it, i just want to design a title, duplicate it and change the text inside but also when I make a change for something else then the text like font or color it will hapend in all of the titles on tineline
    Here's how I handle that: when you copy/paste your original title, then make a change to it, make sure you go to the "File" drop-down menu, and select "Save As," and NOT "Save." This will save your changed title as a new .ETL file, with a different name...and preserving the original.
      If you want to change for all of them ok but If you want keep a model You must save your project in titlepro in "save current design in library" then start a new project and go to the library to find your model
      PC PRINCIPAL: intensificateur 4k pro - edius X- maximus heroX wifi - processeur Intel I7 8700K; mémoire 16 Go SKILL - xpredator2 - corsair 650W HX
        Quicktitler will save as .etl file, New Blue Titler Pro saves as an .nbtitle.
