Video stablizers
  • Video stablizers
    I have had trouble with shaky footage, probably because of these new cameras I use.Sony mirrorless some have image stabilizing some dont. I use Edius 8s image stabilizers tool. Is there anything better my video flickers now actually looks better without it. possibly hte new version of Edius?
    Randy
    Randy
    Randy
    You are mentioning stabilization and flicker, two different problems. If you are not moving to Edius X, stabilization can be done with the built in stabilizer, Mercalli, or running the video through some other stabilizer. Edius X has a new stabilizer in it that looks pretty good from the demo videos, however I have not moved to X yet, as it is still not mature enough or have a required feature for me yet.
    Flicker is when you get brightness flickering in portions or all of the image. Neat Video 5 has some really good deflicker capabilities.
    Edius WG 9.55.7303, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
      I think I mis described it, its not really a flciker its clearly quiver of the software trying to clean up the motion. im using Edius 8 stablizer I since found I had bought mercalli a long time ago and am running version 2. Which seems a little better. Im wondering if Edius 10 does a better job it may be time to upgrade.
      Randy
        can you provide a sample clip? send via antonsvideo.wetransfer.com
          What is the framerate of the footage and the project. Now what describe sounds like possible motion judder from a mismatched framerate or a slow framerate. Hard to say more without a sample or more information.
