BM IP4K
  • BM IP4K
    I would like to take advantage of the opening of this discussion to ask for your help. I have installed Blackmagic Intensity pro 4k on my brand new pc (medion i9 10900K pc, zotac GEFORCE RTX 2080super graphics card ...) and Edius WG10 and am testing. For the preview on my 32 inch Samsung TV it's ok. The problem is that I wanted to record my P2 rushes, directly on the HDMI output of my panasonic HPX-250 camcorder to the blackmagic hdmi input, to benefit from the best possible quality (uncompressed?) And there I am stuck and I don't know what to do. Would there be a procedure for recording and viewing clips at the same time ? Thank you in advance for your help.
    Mohchabi
    FIRST SYSTEM: Supermicro X9DA7, Bi-Xeon E5 2665/2.40GHz, 16GB Kingston ecc, Zotac GTX680, Storm Mobile, Edius 6.55 & WG8, TMPGEnc Mastering Works 5 & Authoring Works 5, PluraEyes 2.0.3,, Vitascene V2 Pro, Mercalli V2 Pro, Vistitle 2.6, Neatvideo 3 & 4, Windows 7-64bit, Adobe Creative Suite CS6, Imaginate 2.0, Eizo CX 27", TV 32' "HD ready".
    Cameras: Panasonic AG-HPX250 & AG-AC90, Sony HVR-Z5, Canon EOS 5D Mark III.
    I can’t help much with Edius x, but best quality would actually be to copy the files to your drive and use source browser to get them into your project. Absolutely no intermediate decode and re-encode that way.
    Edius WG 9.55.7761, various 3rd party plugins, VisTitle 2.9.6.0, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
      yes, copying the files from card to PC will give better quality than capture via HDMI
      you can use source browser and add and transfer to bin direct from the cards
      to capture HDMI, you need to go to the control panel and open the Blackmagic desktop app and set the input to HDMI
      then make the device preset in EDIUS with the correct frame rate and frame size
