Newblue titler files fail to export/render in Edius X
  • Newblue titler files fail to export/render in Edius X
    Hello there.
    Have anyone encountered problem with exporting .NBTITLE files?
    After creating them in newblue titles i succesfully place them on a timeline in edius, but all files fail to export. Log says 'The System Cannot Open the Device or File Specified'
    Fails in rendering as well.
    Am i a deer and just made something wrong? Can't find anyone with this problem.
    I'm exporting in H.264/AVC, but i suppose it doesn't make any difference.
    Thank you in advance.
    wow, you have a render nightmare with 10x more failures than exports
    I am investigating similar issues with the Nb titler
      This failures are all because .nbtitler files export in various configurations, i was searching for a possible explanation.
        I have to say this.... why are there so many issues with edius 10? didn't they test it before release?
          What version of the NB TP7 titler for Edius are you using? You should have 200914
            That the one i'm using.
            That's what it looks like
              I works finally!
              HTML Code:
              https://www.ediusworld.com/ediusxbonuscontents.html?fbclid=IwAR1XKIL2T6ocWphJHdj0k-8rPNmduQ3_ZR96ASG8xolQ0LcPmomTPuEsLg
              4
              If anyone still have this problem there's an update for newblue titler from 14 october.
                Originally posted by maciek View Post
                I works finally!
                HTML Code:
                4
                I'm trying top work out how to update the New Blue titler ..!!!
                  I'm having the same issue and my version is 201011 I just downloaded it yesterday for Edius X.
                    the latest version is 201014
                    you uninstall current version in cpanel and then install the latest
                      Sorry Anton, what do you mean by CPanel ..??? I can't find anywhere to install the program again.
                        Cpanel = Control panel = this is the place you uninstall the current version by uninstalling both items as seen in attached
                        then you install the new version that you downloaded: NewBlueOFXBridgeAndTitlerProForEdius-201014.exe
                        if you do not want the OFX Bridge, extract NewBlueOFXBridgeAndTitlerProForEdius-201014.exe with 7-zip and then just install the titler only from the extracted folder
                          Thanks so much Anton.
                          Just looking at it now. The same version of Titler Pro is downloading. 201011. Where can I find this updated version 201014 ...????
                            download the whole 3.1GB package and extract it, then go to the Bonus folder
                            https://www.edius.net/download/ediusx.zip
                              Thank you Anton
