edius 8 tittle fx
    Originally posted by robchand58 View Post
    As an example, here is a video from the manufacturer explaining his film credits template. It should give you some insight into how these projects handle...
    https://www.youtube.com/watch?v=bFHEOl_HYmg&t=7s
    ​​​​​​thanks for your help with this tutorial now i understand better.
    I7 4790K-32 gb RAM-RX580 8gb-SSD 256gb-Windows 10 pro-Edius8.5-Lumix GH2 Moon T8-Lumix FZ1000-
      Originally posted by GrassValley_PS View Post
      To Use any Project based effort in your current project, Go to the Bin, right click on Root and select Import. Then navigate to the Project you are looking for (whatever the QT project that you bought) Be sure you select the .ezp file. That project and all of its associated files will be displayed in your Bin. Grab the sequence (Let's call it Sequence 2) and drag it to your timeline. If it is for QuickTitler, it will go on a higher track on your current sequence (let's call it Sequence 1). If you need to customize the title (as you probably will), double click it in the Bin. It will open as a separate sequence on your timeline. Make your corrections there in Sequence 2 and those changes will automatically show up in Sequence 1.
      This is basically just a nested sequence. They sell it this way because that is how you will be able to customize it.
      ​​​​​thanks for your help.
        Hello, given the fact that the titles and all the projects in the site are pre-rebuilt presets, for an average user are really friendly & simply to use! There is a tutorial now explaining how to use them for all users...
        https://youtu.be/UFAhawGZwEs
          Thank you so much now I can better understand how to use them.​​​​​​
