Vistitle upgrade & Plugin Question
  • Vistitle upgrade & Plugin Question
    A quick question for you all. I have Vistile for Edius Ver 2.5.0.0 – 64 bit.
    Can I upgrade to “VisTitleSetup2.850_ENG” as a free update without messing anything up? I downloaded it from the website and wasn’t sure if this will work without a upcharge fee.
    Also, I bought the Vistilte Plugin Package from ToolFarm. They gave me a Registration Activation code. It didn’t work with the version I have. Toolfarm is looking into this to why it didn’t work. Do I need to upgrade for this to work?
    Thank you again for your help & time.
    I would have bought the plugin pack directly from HKVisdom.com. Only because they can solve things faster.
    Saving $5 isn't that big of a deal if you can't get it to work.
    You say you have 2.5.0.0. Did you get the free digital license last year? If not, when Vistitle moves to 2.9.x.x, the dongle will not work.
    The dongle will continue to work with all 2.8.x.x versions.
    Uninstall 2.5.0.0 and reboot. Download 2.8.5.0 and install it.
    Reboot.
    Open the Vistitle license manager and add the new plugin pack license.
    Reboot and start up Edius and give Vistitle a go.
      Thank you Jerry.
      As always, this forum is extremely helpful in many ways.
        Were you able to get the plugin pack license to work?
          Hi Jerry.
          Thank you again for the information. I did exacly what you said with the unistall and install with the upgrade. Looks like it when well. On the “Start Program Button” I went to look for Vistitle License Manager, it was not listed. All the other submenues were as shown per your screen shot. I did open Vistile and tried to add the plugin serial number there and it did not except it. Maybe they gave me a bad regerstration activation nomber.
          Quick note.. I’m Running, Windows 7 Profesional & Edius Ver 7.53.31
            When 2.8.0.0 was released, the first version had an issue with licensing.
            I made a video showing how to get around it.
            2.8.5.0 is fine with accepting your dongle or digital license. In your case, go to 1.03 in the video and watch what I did with the plugin license.
            You will need to open Vistitle Standalone manually and then follow the instructions.
            I don't know if it will work or not, but at least give it a try.
            http://forum.grassvalley.com/forum/a...7&d=1531071282
              I seem to get a different view then yours.
                Will it allow you to past your plugin serial number into that space?
                If this doesn't work and you haven't heard back from Toolfarm, go to HKVisdom.com and scroll to
                the bottom.
                Select Contact Us and send them an email explaining your situation. Don't expect a
                reply before Monday.
                While you are in the Contact area, pan right and you will see the Register option.
                Create an account so that you can get the downloads and notices easier.
                They are very responsive.
                  Yes. I can copy & paste the serial number in the space. I did this very carefully to make sure it was right. Then the WRONG SERIAL NUMBER box comes up. I tried several times. I will try what you said on the HKVisdom site. Thank you for trying to help me out.
                    That is strange. Yes, definitely contact HKVisdom. Go ahead and send the email today.
                    You might get a response by early Monday morning.
                    Good luck. If I can help further, let me know.
                      Thank you Jerry. I will do that and let you know the outcome.
                        Hi Jerry.
                        I received a email from Visdom today about my situation.
                        ToolFarm had sent me the digital key version and I have the Dongle version installed on my system.
                        They said that there are two different activations keys for this. They sent me the Dongle version and it worked perfectly.
                        Thank you again for your help.
                        Also, do you know of anyone that has vistitle templates to buy or free downloads. I'm really getting to like this titler with what it can do.
                          Look in my signature for my website link, and go there and look around. There you will find free tutorials. Also, the Vistitle Quickstart Tutorials are available and they come with the Volume 1 Templates.
                          https://forum.grassvalley.com/forum/...ad.php?t=44564
                          In this thread I have posted 5 free templates with a tutorial to show you how to use them.
                          I'm glad HK Visdom was able to help you.
