HitFilm Ignite Pro 4 in Edius 9
  • HitFilm Ignite Pro 4 in Edius 9
    Hello
    Please help.
    After installing HitFilm Ignite Pro 4 in Edius 9 I don't have any new effects. What could be the reason? I will add that it works on Windows 7 Home. Everything is ok in Hit Film pro 14
    How can you manually add Ignite Pro 4 to Edius?
    Regards !!!!
    Sorry for the mistakes I wrote using Google translate
    Originally posted by Marco1978 View Post
    Hello
    Please help.
    Regards !!!!
    A quick search on the Hitfilm support states that Ignite 4 does not support Win7
    The system requirements for it state Win10, but unlike some Win10 software that will run in Win7, Ignite 4 will not run in Win7
    Edius WG 9.55.7303, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 8TB Internal RAID 0/stripe (2x4TB Seagate SATAIII HDD's, Win7 Software stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
      Ignite_Pro_4.1.9221.34279_x64 works fine here in Win7 and EDIUS 9.51
        Not working for me. Did a bit of digging. On an FXHome post, (sorry can't find the link right now), they said it wasn't officially supported by Win 7. If it works for you it may be related to GPU drivers since it does use GPU acceleration if I recall correctly, and/or something else in your install, but there is no guarantee of Win 7 compatability.
        I rolled back to Ignite Pro 4.0.8528.10801 and it works fine for me now.
        I will try updating my GPU drivers, but I am on a GTX680, so even an update may not get 4.1 working due to age of hardware.
          Version 4.0 is part of the 3.0 version. The change over starts at 4.1. It's not worth me upgrading to 4.1 because I have Continuum 2019.5. The Chromakey it that is excellent.
