Edius 8 and Edius 9 plug-ins on same PC?
  • Edius 8 and Edius 9 plug-ins on same PC?
    I only have Edius 8.53 at the moment, but thinking about updating to Edius 9.
    I know you can have Edius 8 and Edius 9 together on the same PC, but what about plug-ins?
    I have Vistitle 2.8, various NewBlue and Prodad products with Edius 8. If I have both versions of Edius on the same PC are the plug-ins shared, or would I have to buy extra licences?
    If I am able to use the existing plug-ins without purchasing new ones, how are they installed if I get Edius 9?
    they will work in both as long as you copy them from the 8 plugins folder to the 9 plugins folder
      Thank you Anton.
      I assume that I can try this out using the trial version of Edius 9?
        the EDIUS9 trial is very limited, I would give it a miss
          How do you mean limited?
            Just because you can have both versions on your system doesn't mean that you shouyld. Maintenance time increases, especially for updates. Personally, I would do a completely clean install for Edius 9 and get it as solid as possible over having both versions installed. Why complicate your life.
              Hi Jerry
              I don't think Edius 8 would get any updates.
              The only reason for me to have both Edius 8 and Edius 9 on the same PC , is to see if I would benefit from an upgrade to Edius 9. If I did get Edius 9 , I would uninstall version 8.
                example: watermark in exported file
                  OK, that's fine . I just want to see what Edius 9 can offer me compared to Edius 8. So 30 days of a trial should do that.
                    Just my 2 cents.
                    I use 2 PC's with both version. It works very well but "certain filter" is not memorise from project saved with 8 and re-opend with 9.
                    This is the case for "stabilization". It ask some times in E8 to be calculated but is memorised in the project files that grows.
                    Re-opening with E8 : perfect
                    Opening with 9 : all clips with stabilization have to be recalculate.
                    For many others filters it is full compatible between 8 & 9.
                    But, I have not made a test for all of them.
                    Main System: Azus Z87 Pro, [email protected], 16gb ram, Nvidia GeForce GT 630, Windows 7 Pro 64, Samsung 840 pro, Edius 8.53.2808 WG and 9.54.6706 + NXexpress or HDspark, 2T separate video SSD.
