After Installing NewBlue TotalFX7 Edius9 crashes ????Help
  • After Installing NewBlue TotalFX7 Edius9 crashes ????Help
    Dear all
    I have installed the new trial version of Newblue TotalFX7 in order to try it
    but edius 9.5 crashes and did not open ?
    help me
    Best to contact New Blue if this is happening a
    After installing the trial version.
      Originally posted by sharif_al View Post
      Dear all
      help me
      Yes, please send us an email to [email protected] and we will be happy to help you with this issue.
        The same here
        Do you have a solution to work with titlerpro 7?
        PC PRINCIPAL: intensificateur 4k pro - edius X- maximus heroX wifi - processeur Intel I7 8700K; mémoire 16 Go SKILL - xpredator2 - corsair 650W HX
          Will the Titler Pro 7 install be the first time any Titler Pro versions have been installed? This is important!!
            yes I did it but no much better
            Is there somebody works with titlerpro 7 with edius with no problem?
              You shouldn't have any problems playing the files with your system.
              1). Do a complete uninstall of Titler Pro.
              This includes going into the Grass Valley plugin folder/New BlueFx/Titler and deleting the plugin.
              2). Reboot
              3). Re-install TP7
              4). Reboot.
              5). Setup the Titler preview and export graphics quality.
              Go to NewBluefx.com or YouTube and watch a bunch of tutorials.
                Originally posted by sachem View Post
                The same here
                Hello Sachem,
                We have been working on improving the stability of Titler Pro 7 in Edius and have a new beta version available, please write to [email protected] and we will work with you to resolve your issues.
                  the answer of NB
                  We are aware of the bug with Titler Pro 7 and EDIUS. Unfortunately, there is no current stable build in progress. Our team currently working overtime to fix the problem as soon as possible. I will inform you as soon as a new build becomes available.
