Hi .....
Anyone else having this issue?
I open Vitascene 3 in E.9. I apply a vitascene video filter and exit back (using the plug-in icon)to E.9.
Video Filter is there and works fine in E.9. But if I want to go back into V.3 to check that filter's parameters, V.3 won't come back up with an applied filter. It crashes Edius.
In other words, Vitascene opens fine before a filter is applied to a clip, but won't open WHEN A CLIP IS ALREADY APPLIED. The only way I can check a video filter is to delete it and go back and just redo it. Annoying!
I don't know what to do about this. Is it a buffer issue? I'm set at 3GB.
A settings issue??
Thanks for any input.
Lori
A settings issue??
Lori
