Best free VST limiter plugin for Edius.
  • #31
    Originally posted by ulyssesvideo View Post
    HI Dave.
    thanks...
    I use the newblue audio plug in... its very good but not as simple to use.
    cheers
    Hi Carl.
    Give it a try, I'd be very surprised if you didn't like it and if it didn't become a 'go to' audio tool for you within Edius.
    Before using LoudMax I'd have to add either my iPad or DAW into the workflow so that I could do certain dynamics stuff for my Edius audio, which meant a bunch of exporting and importing etc.
    Now with LoudMax I can stay within Edius for my entire audio workflow, which makes things much easier. I have a number of options for microphones which means that I don't need to touch EQ, so adding some simple dynamics is all I'd really do anyway with dialogue.
    I also use LoudMax to control peaks in music tracks in Edius as well so I can balance a bit more between V/O and camera dialogue against background music. The addition of EQ also helps for this, which is easily achieved with Edius' own EQ options, but I generally find that I don't even need to do that.
    I'm gonna see if I can dig out a recent mic test where I had accidentally left the mic gain very low and used LoudMax to gain the dialogue to listenable levels. I'll post it here if I can find the original camera file.
    Cheers,
    Dave.
    • #32
      LoudMax to the rescue.
      Here's an example of LoudMax being used to gain up the output of some dialogue that was recorded very low.
      https://youtu.be/XnszaDBWpxc
      • #33
        thanks for that Dave.
        cheers
        • #34
          Hi Dave,
          I think the VST plug-in is very useful, but in the example you give of raising low level recording, there is another quick way.
          Just right click on the audio track that is low, go to the audio properties and you can lift the gain by up to 24dB.
          • #35
            Originally posted by John Hooper View Post
            Hi Dave,
            This method will not protect against driving a peak into clipping. The use of loudmax or another loudness maximizer like elephant will protect against it, since you are compressing dynamic range and setting an output ceiling.
            Edius WG 9.52.6153, various 3rd party plugins, VisTitle 2.8.0.5, Win 7 Ultimate SP1, i7-4790K @ 4GHz with HD4600 GPU embedded, MSI Z97 Gaming 7 Motherboard, 32GB Kingston HyperX RAM, nVidia GTX680 4GB GPU, Matrox MX02 Mini MAX, Corsair 750W PSU, Corsair H110i GT Water Cooler, Corsair C70 case, 4TB Internal RAID 0/stripe (2x2TB Seagate SATAIII HDD's, Win7 Software RAID 0/stripe), 1TB Crucial MX500 SSD, Pioneer BDR-207D, Dual 1920x1080 monitors (one on GTX680 and one on Intel HD4600).
            • #36
              Hi Bern. That's exactly right, thanks for pointing it out.
              One of the problems with audio is understanding the difference between gain/attenuation and dynamics processing. Which all effect loudness and dynamic headroom/range in different ways, as you've just explained.
              I've always found that the easiest way to understand these effects is to just experiment with the various ways and compare the results. Sometimes you'll find that the way you thought would be best sometimes isn't.
              Cheers,
              Dave.
              • #37
                I agree with you, but when one clip is recorded accidentally too low, I would not want to compress or limit just that one item as that could change the natural dynamic range in relation to other clips around it. I would prefer to lift that clip by an amount to bring it into line with the level it should have been recorded at. Then process the dynamics if necessary after that.
                Techniques might have changed since I retired from broadcast sound, but that is the way I would approach that type of issue.
                When working in broadcast sound (PAL) the audio should peak at 8dB above the reference level of -18dB, which gives a headroom of 10dB before clipping.
                • #38
                  Hi John.
                  I'd just use whatever works best for any particular situation. The only problem when something's as low as I had in that recording it usually won't gain up to an appreciable level using just channel gaining. Adding a further a 12db was already shown in the example using the master output. This would be the same as adding 24 to the channel and leaving the master alone.
                  The only problem, like I said in the example, is that gaining with the master fader can and will cause all kinds of issues for the mix itself. So adding 24 at the channel and more at the master, isn't the best way to mix.
                  This is when limiting and re-summing at the channel can be a better option. In my particular example, you'd never hear the effect of the headroom being reduced. In fact, if you look at the channel fader you can clearly see a lot of headroom. Any ceiling in there will simply protect and stay constant and not necessarily be heard.
                  As for transmission standards, PAL in your example. There are many ways to increase the output level while peaking at pre-determined thresholds. This all of course depends on the standards being adhered to. Regardless, dynamics processing can be used to raise average energy levels, perceived volume, without raising peak levels.
                  The problem with standards and/or guides, there's always a way to get around them. No one ever mixes without dynamics, intentional or not, for TV, or any other medium.
                  When you consider that most field recording employs dynamics processing, usually limiting of microphones, you could argue that the overall dynamics have already been tampered with, or destroyed.
                  I personally don't have a problem with dynamics processing as long as it's done to complement or to fix things. Although I can't stand it being used heavy handedly without any thought just to go loud.
                  Like I was saying earlier. Just use whatever way is most suitable to raise levels, as long as it does the job that's required. My example here was only one way that's very easy and may help people who don't have much experience with such things.
                  Cheers,
                  Dave.
                  • #39
                    Yes John, If I had one problem clip, I would also raise it's level as you pointed out, but I would also be wary of those peaks, and may put a basic peak limiter on there that would just cut the peaks without changing anything else.
                    My point was that just turning up the volume can cause other problems if you are not careful. I will often normalize clips to a peak level and hand tweak levels as required, and then put something like loudmax on either a mixdown or nested clip to let that even things out a bit more, being careful not to let the dynamics adjustment cause pumping and breathing.
                    Just to confirm your broadcast note, here in NTSC land we also aim for -10dB.
                    • #40
                      Loudmax
                      Hi all
                      Just read the above threads for since going to Edius 9 from version 6 I haven't been using any audio plug ins.
                      The one I have really missed has been a limiter so I'm hoping Loudmax cuts it.
                      • #41
                        yes, Loudmax does it
                        EDIUS 9 WG with BM Mini Monitor 4k and BM Mini Recorder, Gigabyte X299 UD4 Pro, Intel Core i9 9960X 16 Core, 32 Threads @ 4.3Ghz, Corsair Water Cooling, Gigabyte RTX-2070 Super 3X 8GB Video Card, Samsung 860 Pro 512GB SSD for System, 8TB Samsung Raid0 SSD for Video, 2 Pioneer BDR-209 Blu-ray/DVD burners, Hotswap Bay for 3.5" Sata and 2.5" SSD, Phanteks Enthoo Pro XL Tower, Corsair 32GB DDR4 Ram, Win10 Pro
                        • #42
                          Loudmax thumbs up
                          Hi Anton, WOW that plug in sure works a treat.
                          I just donated and I hope other do as well. It's mighty handy.
                          Thanks to the creators!
