If you are running Edius 7, 8, or 9, just run the installer. Installation is pretty straight forward.
Now, if you have had the TP2 trial, or another version running, I would uninstall that first. Then go to Program Files>Grass Valley>EDIUS Version>PlugIn>NewBlueFX>Titler>
Then delete the Titler20Plugin7.tpi file.
Now, run the TP6 installer.
Then to access the title, open Edius and right click on a V track to choose the titler from the drop down.
