Is the SGDV stick with the tutorials incompatible with Windows 10? I just get a blank with non accessible.
SGDV stick
When you say blank, do you mean the stick is blank or nothing happens when you insert the stick?
If it isn't auto running for you, then you will need to set this up.
Go to Control Panel>Autoplay
If Windows Media Player isn't the default media player, you will get an error, but you're chosen media player should open.
To change this go to Settings>Default Apps> and change the Media Player to Windows Media Player.
Changing to WMP will give you a seamless operation.
I have said this in many posts, you shouldn't use the drive as a playback device. The information should be copied to a hard drive and run from there.
I stated that during the initial release of the tutorials.Last edited by Jerry; 12-16-2017, 06:16 PM.Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black Edius X.
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD. -
I am getting file is corrupt and unreadable even with windows media player. That will teach me I should have transferred the files as you said. Thanks for the reply.E9 PRO ,Intensity Shuttle capture Nvidia 650 TI LG 3D Monitor HDMI Win 10 PRO 64 Bit.Vistitle 2.6, Robuskey. ASUS Z370 I7 8700 16 GB Hyper X black RAM 250GB 960 EVO. 2 ITB DisksComment
I sent you a PM.Jerry
Second System: EditHD Ultimax-i7, X58, [email protected], Corsair H80, Win764, 24gb ram, Storm 3g, Samsung 840 Pro 256, 4tb and 6tb RAID 0 on backplane, GTX 980ti Classified, Edius 9.55, Apple 30", Samsung 24", dual BD.Comment
