Edius 9 and Vistitle
  • Edius 9 and Vistitle
    Hi,
    Has anyone tried the combination Edius 9 and Vistitle?
    I have downloaded the trialversion of Edius 9, without uninstalling Edius 8.53.
    But Edius 9 only proposes quicktitle.
    Is this a limitation of the trialversion?
    Do I need to upgrade my Vistitle 2.6?
    I was planning to upgrade to Edius 9, but this is a real problem.
    Regards,
    Marc Hens
    Edius 9.51 - Panasonic AG-AC90
    desktop: Windows 10 64 bits - Intel i9 9900K Coffee Lake - 32 GB RAM - nVIDIA Geoforce GTX1070 ti (8GB) - 2 TB M.2 SSD for video - 256GB M.2 SSD for software - 4 TB SATA for other data
    laptop: Windows 10 64 bits - Intel i7 6700 - 32 GB RAM - nVIDIA Geoforce GTX1060 - 256 GB m2 SSD + 500 GB Sata-SSD + 1 TB SATA
    copy the vistitle plugin from 8.53 to 9, then it will work in both
    VtEDIUSImporter7.tpi
      Thank You Anton. I will try this at home.
      Is something similar possible for my HD-Storm card?
      I know it is no longer mentioned in the list of supported hardware.
      I'm considering a Black Magic Design intensity pro 4K as a solution.
      Regards,
      Marc Hens
        If you just need monitoring output then the lower cost BM mini minitor 4K could be suitable. Just check that it is compatible with E9 first.
        i9-7900X OC, Asus TUF X299 Mk2 MB, 32GB Mem, 250GB Samsung 960 Evo M,2 NVMe for OS, HDDs for work files, GTX1080Ti 11GB, Win10 Pro 1809, Edius 8.5 WG, Sony FS7 main camera
          Confirmed. The problem is solved Vistitle is visible from Edius 9.
            Regards,
            Marc Hens
            no, several GV cards have been eliminated from working with EDIUS9 whereas they still work with 8.53
            the only GV cards that work in EDIUS9 are:
            • STORM 3G Elite
            • STORM 3G
            • STORM Pro
            • STORM Mobile
            • HDSPARK Pro
            • HDSPARK (may not work with X series v3 chip such as 2011-v3)
              HDStorm no longer works in Edius 9
                This is the official answer for my problem
                https://www.youtube.com/watch?v=Gq6D6KabreM
                or https://www.edius.net/download_plug-ins
                I have received this info after I have used the shortcut-method.
