New transitions
  • New transitions
    Why is it that Edius never updates it's transitions. Why is it that if you need almost anything other than a page curl, you need to rely on 3rd party products like New Blue and others, that although they try, the quality is not as smooth as it would be if it were part of Edius.
    Why can't we have simple, yet powerful transitions like these:
    https://www.youtube.com/watch?v=jbRJL9Nd_YM
    That must be on your end. I have TFX3 and all of those are processed as 10bit. The quality is very good.
    If you're talking about playback, that is system dependent.
      I agree. Don't have quality issues with the NB trasitions.
      Also someone posted a tutorial how to create those kind of transition with EDIUS. There was also a movie showing them. I can't seem to find that post.
      Anyone have an idea? :)
        Think I found one of them:
        https://forum.grassvalley.com/forum/...3&postcount=15
          Either way, there are plenty of 3rd party FX plugins.
            Yes and doing your part as a paid editor can add a lot of value to your productions.
            Customers can buy all those transition packages and stick their IPhone or Samsung phone footage. :)
            It is good to do something they can't purchase...... Amaze with creativity.
              on the topic of transition i want light ray transition and flash bulb transition how is nb glow transition. what other company has light ray lens flare transition .
              AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
              SSD: 512GB Intel(R) 660P SERIES PCIe NVMe M.2 SSD
              850 power suply
              32GB (8GBx2) DDR4/3000MHz
              ASUS TUF X470-Plus Gaming AM4 ATX
              EVGA GEFORCE RTX 2080 SUPER GPU
              Windows 10 Pro
              HDD: 8TB (8TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM
                Prodad and Sapphire are 2.
                  whats TFX3?
                    Originally posted by ulyssesvideo View Post
                    whats TFX3?
                    I have it, TPFX3 = New Blue Total FX3 (the lot in one installer)
                      Is it any good?? are they 10bit?
                        if project setting is 10bit, the NB filters and transitions will be 10bit
                        to be honest, I am a cut and dissolve only man, I hardly ever use any of them unless a customer insists
                          example, each NB transitions has presets within, see attached
                            If you look in the stickies under Favorite effects, I have a white flash included.
                              yes i have it nice i want lens flare i try saphire but pricey
                              850 power suply
                              Windows 10 Pro
