noise reduction plugin
  • noise reduction plugin
    I"m looking for a plugin that allows noise reduction in an audio file. Currently I use an older version of adobe audition for that purpose but I don't want to be taking any roundtrips and do this right in Edius.
    Are there any good plugins available for Edius 8WG?
    Loads of suggestions, not all plugins - USE SEARCH!
      What's your budget? Wavearts has a good Master Restoration plugin as does Izotope.
        I recommend Wavearts Master Restoration as it is the only plugin for EDIUS that causes 0.0000% delay after export
          Is Wave Arts better than Adobe Audition?
            I have no idea
            Wavearts is a VST plugin and works direct in EDIUS
              It works in both Audition and Edius. It's better in the sense that the plugin keeps the work within Edius. I use both but prefer to keep it native.
                Thx for the suggestions! I"ll have a look at wavearts.
                  Ok thanks, I don't mind going round trip and to Audition and back, just wondering if the noise reduction was better or not.
                    As far as removing fan and computer noise on voice overs I do find it better. As I said before, it can be used on Audition as well.
                    It takes less work to get the same quality noise reduction, even when using it in Audition.
                    I also have the Power Suite, which has the individual elements of Master Restoration.
                    Out of this, I use MRGate and MRNoise. Using these two items takes care of any noise issues I will run into when doing
                    my voice overs.
                      Anyone know if this plug-in is any good?
                      https://acondigital.com/products/restoration-suite/
                        my voice overs.
                        Thanks, Jerry.
