copyright c
  • copyright c
    Is there the copyright c with the outer ring hidden anywhere in the vistitle fonts
    Intel i7 6700k, Gigabyte GA-170-HD3 motherboard, Edius pro8, windows 10 pro, 16 gb ram, 256gb SanDisc ssd system drive, Geforce GTX960 graphics card, Blackmagic Intensity Pro4 video card.
    alt+0169 = ©
    You can also open the character map in vistitle with alt +t
      Just a little addendum to what Steve said:
      The alt+0169 and character map are not VisTitle specific. Thos are functions that operate in Windows in general and will also work in other programs.
      If you happen to be using a strange font however, you may find a different character in the alt+0169 position, as it essentially calls the 0169 position in the font file, and sometimes you may have font that has a different character in that position. This is where the character map can help to find it's location, or you can switch to a different font.
        also note that vistitle has a built in character map which shows you all available symbols of the selected font and you can select any without knowing any shortcut code
          Which opens with alt + t. :)
            or a mouse right click :)
              Hi, thanks all, much appreciated.
