Robuskey License Manager
  • Robuskey License Manager
    Just tried to use Robuskey and it tells me the program is invalid and to check my license status by Robuskey License Manager. Where do I find this Robuskey License Manager?
    i7 3930K, Win 10 pro 64 Bit.
    RAM 32 GB.
    ASUS P9X79-Deluxe.
    PS Thermaltake 1kW.
    Graphics Gigabyte GTX1660 OC.
    it is in the extracted installer file, do you still have the installer file? see attached
    also, make sure PC date and time have not changed
      Thanks Anton. Found it. Now it tells me that my serial number is invalid. Should I uninstall Robuskey and re-install it again to solve the problem?
      RAM 32 GB.
      ASUS P9X79-Deluxe.
      PS Thermaltake 1kW.
        when is the last time it worked?
        send an email to ISP support and within 24 hours, you have a new activation, be sure you send them your machine ID as generated by the Robuskey License Manager
          Thanks again Anton, I will e-mail them the information that you mentioned.
          RAM 32 GB.
          ASUS P9X79-Deluxe.
          PS Thermaltake 1kW.
            Much to my embarrassment, I have fixed my Robuskey problem. I was using it as a plugin for Edius 8WG in Win7, but have now changed to Win10. In the process I forgot to DEACTIVATE it. Did that, and activated it in my current system and all is OK again. Thanks for all the advice, it made me look and think!
            RAM 32 GB.
            ASUS P9X79-Deluxe.
            PS Thermaltake 1kW.
