Export AAf failed....syntax is incorrect
  • Export AAf failed....syntax is incorrect
    Hi! I have following problem. I export AAF from Edius to Pluraleyes. I normally import the AAF....sync and export to media composer and everything works perfect. But lately I get this error after exporting to Media composer
    "Export AAF - boost:filesystme::copy_file: the filename, directory name or volume label syntax is incorrect"
    So I go back to the created export folder from PL and its just empty.
    Footage is the same frame rate....Everything is ok. The synchronized step is succesfully completed but after export it shows me that message.
    Any idea?
    I5 4690 CPU
    MOTHERBORAD GIGABYTE GA-Z97-HD3
    RAM 8GB [email protected]
    AMD RADEON HD 6800
    2X2TB WD CAVIAR BLACK (RAID 1)
    2X2TB WD CAVIAR GREEN (BACKUP)
    1 OCZ SSD 128GB
    Windows 7
    Edius 9&8 Workgroup
