I have a problem with Pluraleyes 4 in edius 8 ?
  • I have a problem with Pluraleyes 4 in edius 8 ?
    Dear all ,
    after I have synchronized all clips in pluraleyes 4 and export them for edius
    and I tried to import them as usual I got this message :
    help me please I am not able to do anything
    Help me
    This usually happens when you are syncing mixed frame rates OR if your footage in PE is say 50p and your project settings are 25p.
      Ok, but how to solve such a problem?
        I need to know the specs to answer this.
        1. What type\s of frame rates are you bringing into PE?
        2. Are you syncing One cam to sound or more than one cam?
          I shoot 1080/50i
          I did all possible choices but nothing works
          Two cameras with the same recording format 1080/50i
            If your project setting is 50i (25i), there should be no issue. Is you project 25fps i?
            Send me the log file as well. I will check it.
              Are you importing into Edius as FCP XML (as you should be)?
                which log file you want
                I tried to send you ErrorLog using the attachments but it does not work
                  You can upload a zip file so zip it first.
                    Dear
                    I do not know why it is not possib;e to attach it even in ZIP format
                    I attached you the file as jpg
                      Doesn't seem to be any indication to why it wouldn't import. I would need an example file to test it by me. If you can upload those two files to me, I'd be happy to test it here by me. You can upload without registration here:
                      https://new.myairbridge.com/eng/en
                      To my email: [email protected]
                      Also, first try to update the PE to the latest version (4.1.3 1103) and try again.
                        I am sending you two sample files I recorded today
                        they are small
                        have the same recording formats
                        The version is up-to-date
                          I think you have received them in your email
                          now
                            Also by me it doesn't open. In PPRO it opens fine. Let me check if it's a codec issue.
                              ok, it's a framerate error in PE. It thinks it's 50 fps. sec, I'll give you a solution soon.
