Voxengo Redunoise 1.6 on edius 7.53 pro 64-bit?
  • Voxengo Redunoise 1.6 on edius 7.53 pro 64-bit?
    please, how to use 32bit VST Redunoise in edius 7.53 pro 64-bit,
    I am using windows 8.1 pro 64bit,
    I can install it but edius does not see it in effects
    Help please
    Edius 7 and 8 require 64bit vst's. I only saw a 32bit version for download.
    From the website:
    "This plug-in is compatible with Windows XP computers (2 GHz dual-core or faster processor with at least 1 GB of system RAM recommended). Note that this plug-in may not work correctly on the latest Windows versions that expose more than 2 GB of available memory to the host audio application. Otherwise it is suggested to run this plug-in by bridging (for example, by using jBridge). Also note that this plug-in may not work correctly with some 64-bit host audio applications via bridging."
