TMP problem
  • TMP problem
    Suddenly having difficulty doing a "save as" in TMP. It does not save to where I save it to. Any idea why? Using Edius 6.08.
    Thanks,
    Ara
    there is a certain file that needs deleting to restore TMP to normal operation when it acts up
    I am currently on the road, will look later
      Will wait patiently for the answer.
      Thanks,
      Ara
        can you supply a screenshot of all files in the TMPro installation folder, as soon as I see I will remember the file that needs deleting, it has a strange name
          Attached are 3 shots.
          Thanks,
          Ara
            rename inscribe.ini to inscribe.ini-old
            start EDIUS and add title and see if a new inscribe.ini is created, see if problem is solved
            if not:
            rename inscribe.templates to inscribe.templates-old
            start EDIUS asnd add title and make sure a new one is created, see if problem is solved
              Did as you suggested and the attached picture is what pops up as an error. Edius crashes on both your suggestions.
              Thanks,
              Ara
                did you make the changes with EDIUS closed?
                  All set. Thanks a million Anton.
                  Thanks,
                  Ara
                    This problem is back. I keep getting the dongle error anytime I change or create a title. A new inscriber.ini was created when I renamed it to old. The inscriber. templates did not create a new one. Either way it is not working. Shall I reinstall TMP? I still have the files.
                    Thanks,
                    Ara
                      do you have the latest version for EDIUS6?
                        I tried to find the path from your attachment and could not locate what you are asking for. I have the TMP disc for 4.0 but when 6 came out there was a 3 part file for TMP that I also have. Am I missing your question?
                        Thanks,
                        Ara
                          what is the version number of the latest setup.exe you have?
                          every installer has a setup.exe
                          if you don't have the latest installer, I send it to you
                            Attached is what I hope you are asking for. If not please direct me to the correct path.
                            Thanks,
                            Ara
                              that is not the setup.exe (you are showing already installed file)
                              the setup.exe is on the installation disk or downloaded update installer
