trying to bridge rx to edius 8
  • trying to bridge rx to edius 8
    hi guys,
    I am simply trying to bridge rx plug-in pack trial version (like a light version of rx5) into edius 8.22.
    I have tried every option including the obvious settings>system settings>vst plugin bridge>
    Then I will point to c>program files(x86)steinberg>vst plugins.
    i have checked and can see the rx 5 files in that folder ..but nothing.
    I restart and there is no rx5 audio filters in edius 8 folder.
    please help
    Originally posted by Brookes View Post
    hi guys,
    please help
    that won't work because x86 is the 32bit installation, you need the 64bit found in program files......
      Hi anton
      Still having no luck. I have now installed rx5 trial and simply trying to vst plug in bridge c-program files-steinberg- vst and no luck.
      What on earth am I doing wrong...is it because its trial.
      Thanks mate
        after you set the path to VST, you must restart before you see it in EDIUS
        I use RX3 so I am not sure if RX5 will actually work?
          Hi Anton,
          Yes I have done that...I have tried everything..gee wiz.
          I keep linking vst....could it be its a trial version..hmm..doubt it heh.
          I am open to ideas..I have exhausted all mine
          I just read you last comment, "not sure if rx5 works"
          The thought crossed my mind too..there seems to be no support on there website for plugin but grassvalley say on there site that it's supported.
          Its a standalone product as well however I really would love to have plugin for small jobs.
            do you see the installed VST in windows explorer?
            there should be many dll files, see attached
              Indeed
              Many dll files
                Got it Anton.
                Thank you sir. The folder labelled effects has appeared under the audio filter folder.
                Cheers. Have a great day.
                Rob
                  Yes, RX5 does work and quite well for that matter.
                  Here is a screen shot of my path and the folder:
                    Thanks jerry.
                    Liked the old rx3 so 5 should be sweet.
                    Cheers again
