Is it worth upgrading to version 6 from 5? What is the main difference in 6?
Upgade to TMPGENC 6
Upgade to TMPGENC 6
tdtinker
New system: Asus X99 i7 6900K 3.2GHz, 32GB DDR 4 Ram, GTX 1070 Edius 8.5
www.actvp.comTags: None
For me "Yes", since I relay on slightly better quality deinterlace using Interpolation - High Precision.
In the Help file they say following about the metod:
This high-precision adaptive interpolation method which was optimized and also enhances the referring and comparing algorithm from the already implemented [Interpolation - Adjusted] method. By utilizing this new method, it reduces jaggies and flickering pixels with higher accuracy compare with the [Interpolation - Adjusted]. Since this method analyzes the picture's characteristics in quite some detail, the processing speed is slower than the [Interpolation - Adjusted] method.
This was the major upgrade reason for me.1st System: Edius 9, TMPGEnc VMW6 & AW5, ASUS P9X79, Core i7-3930K, Intel SSD 330 180GB, GeForce GTX 570, Corsair Graphite 600T Mid-Tower, Sony Optiarc AD-7280S, 16GB RAM, 12TB , Canopus ADVC-300, 2nd System: Edius 9, HP ZBook 17 G3, i7-6700HQ CPU @ 2.60GHz, 16GB RAM, 512Gb SSD, 1 TB HDD. Cameras: Panasonic DVX200, Fuji X-T3, Sony RX10
What is your OS, Edius version, and Intel driver version. Also, are you running dual monitors or a single?Jerry
Main System:: Azrock z690 Taichi, [email protected], 64gb ram, Lian Li Galahad 360mm in push pull, Lian Li 011 Dynamic XL ROG case, 13 Lian Infinity fans, Win11 Pro , Samsung 980 1tb boot NVME, 2TB Sabrent M.2 NVME, 2 TB WD 850x NVME, 1TB Samsung SSD, 12TB Raid 0, BM MINI MONITOR 4K, , Dual LG 27GK65S-B 144Hz monitors, GTX 1080ti SC Black.
To add to Jerry's post, also what motherboard and CPU do you have?DVC Built Clevo P775DM3-G Laptop with UHD screen, 7700K [email protected], Geforce GTX 1060 6GB GPU, 500GB M.2 Primary, 1x 480GB SSD, 1x1TB M.2, 1x 2TB 5400RPM Video drives, external Blu-ray Optical
Originally posted by Jerry View PostWhat is your OS, Edius version, and Intel driver version. Also, are you running dual monitors or a single?
i run single monitor, but display adapters are both visible in Device Manager.
Motherboard Asus VIII Hero and CPU 6700K
in Edius, i can choose QuickSync with TMPEGEnc plugin, but it wont work, gives a error.
i was hoping that next update automaticly fixes that :)
it should be out in a second :)
AivarLast edited by Aivar00; 04-24-2016, 03:51 PM.
