VisTitle 2.6
  • VisTitle 2.6
    Anybody got VisTitle 2.6 working on windows 10?
    Cant get it to load it just keeps saying load Edius first
    iMac (Retina 5K, 27-inch, 2016
    4 GHz Intel Core I7
    32GB 1867 MHz DDR3 Memory
    AMD Radeon R9 M395X 4096 MB Graphics
    What do you think about the name of your thread?
    If I want to start a thread related to VisTitle 2.6, should I follow your logic to give it the same "proper" name "VisTitle 2.6"?
    Let us hope that there are not 10 other dukes having the same genious idea...
    Andreas
    Andreas Gumm
    post production / authoring
    Windows 7 Ultimate,
    GV hardware: 3G Storm
    PC 2
    GV hardware: HD SPARK
      Works fine here. Do you have the latest installer? You might have to adjust the install path. I don't think I had to do that, but I honestly can't remember.
        Do you have Edius 8.1 installed on Windows 10
          Hi Jerry
          I’m running trial version 8.11.94
          I have Eduis 6 if I can get vis-title 2.6 to work I’ll upgrade to Edius 8
          Thanks John
          4 GHz Intel Core I7
            Can I get a screen shot of your Edius 8 plugin folder.
            This is at Local disc>Program Files>Grass valley>Edius 8>Plugin
            If you have a listing for Edius 7: Could I also get a screen shot of
            Local disc>Program Files>Grass Valley>Edius 7>Plugin
            The plugin may have been installed into the Edius 7 Plugin location.
              Can't see Edius 7 Plugin
              4 GHz Intel Core I7
                It isn't there, so let's try again.
                Is the dongle installed into the machine with Edius trial? Here is the latest driver which does work with Win 10:
                ftp://ftp.cis-app.com/pub/hasp/Senti....8_Windows.zip
                Install the dongle first and then try installing Vistitle 2.6.
                As you do the install process, look at where the program is being installed. It needs to feed into the Edius 8 plugin folder.
                  I have Edius 8.11 working on Windows 10 with Vistitle 2.6.
                  I don't have Vistitle listed in the Edius 8 plug in folder though, but it is working fine.
                  There is a Vistitle update 2.606 here, which might help:
                  I see you are running it on an iMac using Bootcamp. I wonder if this is an issue?
                    Do you have an Edius 7 folder within the Grass Valley folder? I don't remember doing anything special to get it into the Edius 8 plugin folder.
                      Hi Jerry
                      Ok Installed the driver from your above post, with the dongle in tried installing with no success.
                      Just a note its Vistitle 2.5 I’m installing with the free upgrade download to 2.6.
                      No don’t have an Edius 7 folder within the Grass Valley folder.
                      John (above) noted im running this on an iMac using Bootcamp. I wonder if this is the issue?
                      Do I need the Edius 6 Dongle plugged in using this demo 8 version?
                      4 GHz Intel Core I7
                        I don't want to jump in too much here, as Jerry is very good at sorting out issues.
                        You don't need a dongle for Edius 8, but have you already got another version of Edius on your iMac?
                        You will run into issues if you have the trial version and another version of Edius on the same computer.
                          Need a couple of screen shots please.
                          1. Device Manager
                          2. Grass Valley folder
                          3. Program files folder
                            If you have both versions 6 and 8.1 on the same computer that might be your problem. As I said earlier I am sure it is seeing the wrong install path.
                              1. Device Manager
                              Hi Jerry
                              Thanks for your time with this, attached are the screen shots
                              4 GHz Intel Core I7
