Boris FX 10
  • Boris FX 10
    i maybe left out of the loop here but to cut the story short - i purchased boris fx 10 a year a go.i have working serial etc.
    can edius 8 run boris fx 10 64 bit version?
    i installed the software but it does not show in the fx palette in edius 8.
    what to do? any tips?
    Did you do a custom install and direct it to the Edius Plugin Folder
      I made the following video tutorial to help users install older versions of Boris RED with EDIUS 8
      Sorry, we couldn’t find that page
      You are asking about Boris FX.
      I am not sure if the same workflow would work for Boris FX as well.
      If you cannot get John's suggestion to work, it might be worth looking at the possibility of fixing the problem by using the idea in the tutorial.
      Regards
      Douglas
      Creator of Video Tutorials for mere mortals at https://www.gaijin-eyes.com
      Main System: EDIUS WG 9, Asustek Intel Z370, i7-8700K @ 3.70GHz, 32GB RAM, GTX-1080Ti, BMD Intensity Pro 4K, Windows 10 Pro
        Regards
        Douglas
        Thanks for the tips and I watched this video of yours. Very good video.
        Boris FX 10 started working by installing it to the plugin folder but
        it needed some extra reebooting, in my case. Edius also crashed once while installing. My Boris FX 10 is designed to work in Edius 7 but it worked also in Edius 8. Once again, thanks for the help.
