Installing Boris RED into EDIUS 8
  • Installing Boris RED into EDIUS 8
    If you have a version of Boris RED 5 or 5.5 released before 24th.December, 2015 - it will not automatically be installed into EDIUS 8.
    The newer versions of Boris RED, released after 24th. December, 2015 will automatically detect EDIUS 8 and install it correctly.
    I have uploaded a tutorial to Vimeo to help explain one method of getting EDIUS 8 to "see" your earlier Boris RED 5 or 5.5 installs.
    https://vimeo.com/150301770
    The method will only work if you have a valid installation of Boris RED on your computer.
    To avoid this procedure, the easiest way is to download the most current version of Boris RED 5.5.3 from the Boris FX download area.
    It will automatically recognise EDIUS 8.
    Regards
    Douglas
    Creator of Video Tutorials for mere mortals at https://www.gaijin-eyes.com
    Main System: EDIUS WG 9, Asustek Intel Z370, i7-8700K @ 3.70GHz, 32GB RAM, GTX-1080Ti, BMD Intensity Pro 4K, Windows 10 Pro
