NewBlu Titler
  • NewBlu Titler
    I note that having the NewBlu Titler in the plugins folder causes Edius 8.1WG to leave the edius.exe running at Edius exit, and it cannot be re-started until it is closed manually.
    Removing NB Titler from the plugins folder fixes the issue.
    Sys4: Z10PE-D16WS MB 2xE5-2696 Xeon 64 active logical cores. EWG9. 64G RAM. Aorus GTX1080Ti. 55" Q7 1500 NIT HDR 4K TV/Storm 3G Elite/Decklink 4K 12G/8CH audio monitoring, Yamaha RXA-870 A/V. Sys1-3 EWG8 + RX-E1+HDBX1000 MIP in HP xw8600 2 x X5492 CPU 8 cores, 8Gig RAM, Quadro FX3800. All sys Fibre to central media pool - 5TB Axus Yotta RAID + QLogic Fibre Switch. Central VCR rack plus YUV & audio to viewing room with Yamaha AX1 7.1 100 watt per channel amp with 1000W sub 63" HD 3D Samsung TV
    Which version of Titler Pro? TP4 works fine. If you are running TP2, or TP2 installed with the Beta OFX Bridge, you will get the hang.
      NewBlue provided me with a link to NBTPro3-151008.exe for use with 8.1.
      Can't recall any problems with NBT3 but have since reverted back to E7 on Win 7.
      Sys1: Gigabyte Z370 HD3 i7 8086K(4.3Ghz), 16Gb ram, 256Gb SSD system + 2x2Tb video drives, Graphics: nVidia 1060, (W10 Pro) BM IP4K, E8v3 WG; Vegas Pro18; DVD Architec,t 5.2 GH2(hacked), Pana HC-X2000E, GoPro5
      Sys2 :Clevo i7 6700K 3.5Ghz,16Gb ram 2565Gb SSD + 1Tb, (W10 Pro), Software: E8v3 WG; Vegas Pro17
        TP3 will work with Win 7 as well.
