NeatVideo;Version 4.1
  • NeatVideo;Version 4.1
    There is an update for version 4.1
    https://www.neatvideo.com/
    MPPais
    I have 4 and am still not 100% convinced it's better, nor that's it's better than Noise Reduction II.
    I keep having issues using the auto detection, it simply has no effect, at least not visually, unless I go in and spend time fiddling, which is laborious as there is no output screen update, can't see jack on the silly computer monitor, I want realtime output updates whilst inside Neat, maybe I'm missing how to do this.
    NR2 in AE is better, less plastic, better detail out of the box.
    Paul :-)
      Paul,
      What is Noise reduction 2? Is this Neat Video 2 or a different product?
        It's this:
        http://www.redgiant.com/products/denoiser-ii-color/
        sorry I kinda got the name wrong...
        There's some samples to see on my blog
        Paul:-)
          Thanks Paul. Any hope of this working with Edius 8?
            nope, I think not, you can access it through the AE bridge, but when activated on a clip it produces a blank image.
            The bridge never really delivered, such a pity it only handles a few plugs correctly.
            Paul :-)
              Too bad. At least there is the Neat plugin. I am going back and fourth about if I want to spend the time de-noising footage. I don't use a lot of gain but do need about 6db from time to time.
