vistitle upgrade
  • vistitle upgrade
    i have vistitle for 6.5 edius now i have edius 8. where to get upgrade and how much . looking at bh http://www.bhphotovideo.com/c/produc...l/prm/alsVwDtl
    it 284 for that they told me it work with eduis 8 . not much diferent with new blu price wise so i am bnot sure which to get.
    AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
    SSD: 512GB Intel(R) 660P SERIES PCIe NVMe M.2 SSD
    850 power suply
    32GB (8GBx2) DDR4/3000MHz
    ASUS TUF X470-Plus Gaming AM4 ATX
    EVGA GEFORCE RTX 2080 SUPER GPU
    Windows 10 Pro
    HDD: 8TB (8TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM
    You can buy an upgrade from 1.x to 2.x for a lot less
    http://www.dvc.uk.com/cgi-bin/ss0000...TB=O&ACTION=Go!
    Once purchased you install V2.x and it will ask for the serial number from the upgrade
      http://www.videoguys.com/software-for-edius-6297.html
      This also includes all of the plugins.
        Do you know is you have version 1 or 2? Version 2 will work will both versions of EDIUS.
          version 2.0 how do i make it work. i try to download the 2.606_eng update but it pop up said you need a 2.5 version. can any one help here. just upgade my edius to 8 so i have been out of the this forum.
          850 power suply
          Windows 10 Pro
            download the full version 2.6 and not the update version
            the full installer is around 1GB
              thank anton let me try
              850 power suply
              Windows 10 Pro
                ok which one? Anton update i got it to work thanks Anton and all. feeling good.
                850 power suply
                Windows 10 Pro
                  the full installer is here
                  http://www.vistitle.com/view.asp?Id=98
                  choose German or UK server for fastest download
                    thanks Anton best! got it on edius 8 now and all that help me. did not knoew it was a free upgrade like the vitascene.
                    850 power suply
                    Windows 10 Pro
                      It's only a free upgrade if you already have version 2.x. If you'd been running on version 1.x then you would have had to pay for an upgrade, although still not the price quoted on your first post.
