newblu titler pro 4 trial version
  • newblu titler pro 4 trial version
    i instaled and try it it work great but my quick sync check box is gone and no more fast speed encoding for mp4 . any one have this problem?
    AMD Ryzen 9 3900X 3.8GHz [4.6GHz Turbo] 12 Cores/ 24 Threads 70MB Cache 105W Processor
    SSD: 512GB Intel(R) 660P SERIES PCIe NVMe M.2 SSD
    850 power suply
    32GB (8GBx2) DDR4/3000MHz
    ASUS TUF X470-Plus Gaming AM4 ATX
    EVGA GEFORCE RTX 2080 SUPER GPU
    Windows 10 Pro
    HDD: 8TB (8TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM
    Which OS are you using
    Have you checked the setting in Bios
      Re-install the Intel driver and see if that brings it back.
        Hi John using window 10 . where is the setting in bios ?
        850 power suply
        Windows 10 Pro
          ok i will try that but if i uninstalled pro 4 tiler it back.
          850 power suply
          Windows 10 Pro
            What driver version are you using?
            https://downloadcenter.intel.com/dow...t-3rd-Gen-BYT-
              What driver version are you using? Look for the driver ending in 4300.
              not sure what driver where do you look for it ? let me try iton my main pc this is on my laptop edius 8
              850 power suply
              Windows 10 Pro
                Try the driver listed in my last post. It should work with Win 10 and Edius 8.1.
                  Its under advanced not sure where as i am out
                  iGPU should be enabled
                    Does your laptop have two graphics adapters? In some cases the the Intel can not be used with multiple adapters.
                      no does not let ,e try download new driver . i tried the other pc with window 7 and it good the quick sync is there but that what happen to lap top it was good for a while couple of title i made than it just gone.
                      850 power suply
                      Windows 10 Pro
                        I don't understand that. You should be able to download the new driver and install it overtop of the previous version.
                        Is there a yellow exclamation point on the Intel driver entry within the Device Manager?
                        If you uninstall Titler Pro 4 does the box return? If you uninstall TP4 can you then install the new driver?
                          hi jerry trying that now
                          850 power suply
                          Windows 10 Pro
                            yes Jerry if i uninstalled the pro 4 the box return.
                            850 power suply
                            Windows 10 Pro
                              my window 7 with the pro 4 installed is fine the quick sync box is still there.
                              i am using this as my main editing and laptop for simple edit to you tube . hoping i can solve this problem with the window 10 laptop. thanks for all your help! oh yes i did instaled the upgrade graphic card Jerry did not work .
                              850 power suply
                              Windows 10 Pro
