Does Revision FX plugin work in Edius 6.x or Edius 7.x?
  • Does Revision FX plugin work in Edius 6.x or Edius 7.x?
    I'm a big, big fan of REvision FX plugins and wanted to know if they work in Edius 6 or 7?
    http://i.imgur.com/my8chmc.png
    According to REvision's website, it says they work with "After Effects, Avid, FCP, HitFilm, Nuke, Premiere Pro, Scratch, and Vegas Pro".
    I would love to find a way to make the current plugins or older versions to work with Edius 6 or 7. Pls let me know your experience with them, thank you.
    I use Revision plugs in AE and some of them work in Edius 7.5 which is the version I am running currently - can you specify which plugs you want to use and I can test and report what they do - all this via the AE Bridge of course
    Paul :-)
