Filter to smooth slider footage?
  • Filter to smooth slider footage?
    Is there a filter in Edius that can help smooth out uneven slider footage? Occasionally, the slide will speed up or slow down slightly and it would be nice to smooth it out so it's less noticeable. Any ideas?
    Lee - download a trial of proDAD Mercalli V4 Plugin Video Stabilizer. It's the best one out there, and even though many guys approve of the built-in EDIUS stab, Mercalli does a MUCH better job of smoothing out a rough (variable speed) pan as well as general pix stabilization. I've used it for probably 8 or 9 years, and have tried them all. The EDIUS Stab is faster to work and doesn't smooth out a rough pan nearly as well, and I think the Mercalli is worth the small wait per shot.
    Video editing programs and video software from proDAD are the perfect solution for creative video projects. Optimize and stabilize your videos perfectly!
    Wow - Lee. I just searched for it myself, and the cost has gone up quite a bit.
    Good luck,
    Alan
    Alan J. Levi
    Director
      Hi Alan
      I think he means the person who moved the camera on the slider did not move at an even speed and he wants to iron that out. I know of no simple way
        Hi Alan
        I may be wrong Anton but Mercalli set to "GLIDE" does a decent job of a hand held pan so movement along a slider should be even easier
        Barry
          Barry
          ahhh, I have to try that to believe it
            Anton - Barry's absolutely correct - that's why I suggested that. "Glide" works like a charm on uneven speed of pans, hand-held or slider.
            I can hardly believe I finally won one against the "Master"! Now, even though your collection of fine wines is infinitely better than anything I have here - I'm going to have a glass of Australian 2005 Beck Burgenland Pinot Noir to celebrate!
            Best to you, Anton.
            Alan
            Alan J. Levi
            Director
              Best to you, Anton.
              Alan
              Hi Alan, Burgenland wine comes from Austria, not Australia
              the reason I never tried glide is because I never managed to perform an uneven pan or slide, I will test this when I get a chance
                Yes, it's to smooth out slider footage where the slider speed sped up or slowed down slightly. It's not a drastic speed change, just barely noticeable but still would be nice to smooth it out. I've used glide successfully to even out glidecam footage maybe I'll try it on this. I have an older version of Mercalli, probably 2.
                What is the Edius stabilizer you're talking about? Not sure I see that.
                  the EDIUS stabilizer is found in Filters and is called Stabilizer
                    My goof on the Pinot, Anton! No wonder it wasn't quite Australian quality. Loved your even pans, though.
                    Alan
                    Alan J. Levi
                    Director
                      Thanks, Anton. Never noticed (or obviously used it) before. Will check it out.
                        Is Stabilizer a new filter? I have v6.08 and can't find it anywhere.
                          Yes, new since Edius 7.somewhat.
                          Intel Core i7-7820X ---- Noctua NH-D15S ---- MSI X299 GAMING M7 ACK ---- 64GB RAM 2666-15 Corsair Dominator Platinum ---- 500GB Samsung 960 EVO M.2 (system SSD) ---- 512GB Samsung 960 PRO M.2 (data SSD) ---- Aorus Nvidia GTX 1080 Ti ---- be quiet! SILENT BASE 600 Case ---- be quiet! Dark P. Pro P11 850W ---- Win10 Pro ---- Edius WG 8.53.2808
                            I had it on Edius 6.5. Can't remember if it was on Edius 6.
                            I tend to use the glide setting in Mercalli most of the time. Mostly used for shoulder mount camera shakes. Works great
                            Raja Singh
                            Sadha Video
                            UK
                            Gigabit Ethernet
                              Seems like the older I get, the more I use the Glide setting. Strange, isn't it ! !
                              Alan
                              Alan J. Levi
                              Director
