Hello guys need your help
  • #31
    you don't need to choose any folder during installation
    I only told you where the dyna effects will be found
    be sure your windows explorer is set to show hidden files and folders otherwise you won't see the program data folder
    • #32
      Well Anton my windows explorer is not set to hidden, everything shows up.
      Vexel\VisTitle\Library\SysLib\DynaT exture\ is still not under folder programData or VisTitle plaese attch.
      MICHAEL
      EDIUS 8.1
      Operativsystem win7 pro 64-biter: Motherboard X79 extreme 11: Processor Intel Core i7-3930K 3.5Ghz: Ram 32GB DDR3,2133MHZ: Graphiccard Nvidia GTX 680 4GB PhysX CUDA: MAIN drive Samsung 840 PRO SSD RAID 476 GB: SECOND driver WD RAID0 1.81 TB:
      THIRD drive workstation G-Driver 12 TB external plugin USB 3: HDSpark monitor TV 32 inches: Blu-ray burner Asus 12x BD-R 8MB Sata: SONY camera A7S2 & A99 DSLR.
      http://www.nett-one.com
      • #33
        can you change view to details and not thumbs
        also, the Vexel folder is not in program files
        it is in the program data folder which is hidden until you enable show hidden files and folders
        your screenshots clearly show that the menu bar is missing from your windows explorer, this means that you will not be able to select to show hidden files and folders
        to enable the menu bar, click organize, click layout, tick menu bar
        in menu bar, click view menu and enable to show hidden files and folders
        Microsoft assume that all users are without a brain and they do not want to to find anything.........
        • #34
          I have done exactly as you describe here, both menu bar and files folders are enable now, but still nothing showing up.
          MICHAEL
          EDIUS 8.1
          • #35
            Michael, you had mentioned that you had performed a clean install of Win 7 64.
            I just want to be clear on this point. Was this an install on either a clean drive or a drive where everything was erased and then Win 7 installed?
            If you did either of these, did you install specific motherboard drivers or just let windows take care of it?
            • #36
              Hi Jerry
              Yes it's clear install windows 7 on old drive Samsung 840 PRO SSD where everything was erased. Yes I did installed all the driver comes with motherboard. Everything works fin except the hell vistitle template.
              MICHAEL
              EDIUS 8.1
              • #37
                Look, we're trying to help you and that means asking a lot of questions. Just because everything else appears to be working fine, doesn't necessarily mean that it is working fine.
                Actually, by this time I would have either loaded my starter clone or uninstalled both Edius and Vistitle. I would have downloaded the files again just in case either or both of the previous downloads were corrupt. Then I would have proceeded with an uninstall of both Edius and Vistitle. After that, I would have re-installed Edius and then Vistitle.
                To be honest, your issue is sounding more like an install error of either the Host, plugin or both.
                There is always the possibility of a wayward Windows update that whacks some part of an install.
                • #38
                  Can you show us the path that both Anton and I suggested? Did you ever try to drag and drop a file from there that I suggested yesterday?
                  • #39
                    I'm sorry Jerry I know there are a lot of questions, I'm not complaining with your help, I really appreciate, actually I’m very happy about it. I believe the problem is not with Edius but Vistitle. If it helps will try to reinstall both Edius and VisTilte and let you know.. Thank you.
                    MICHAEL
                    EDIUS 8.1
                    • #40
                      I have done exactly as Anton said, it's not possible to drag and drop there is no folder under Vistitle Vexel\VisTitle\Library\SysLib\DynaT exture\ <<< all those folder are not there can't see.. Please see my attch.
                      MICHAEL
                      EDIUS 8.1
                      • #41
                        That is NOT the correct path. Please look again.
                        • #42
                          Will you please explain a little where to look after the path. thanks.
                          MICHAEL
                          EDIUS 8.1
                          • #43
                            It is really very simple. Go to C:\ProgramData\Vexel\VisTitle\Library\SysLib\DynaT exture\DynaTexture1 and see if you can drag and drop one of those files into the Bin.
                            Here is the quote from previous post. Follow the above path.
                            • #44
                              You need to go to your control panel>Folder Options>and Find the line item folder Labeled 'Hidden Files and Folders' and select 'Show Hidden files.' Apply and you will see the Program Data option.
                              Watch this video:
                              Dyna Texture folder.mp4
                              • #45
                                Hi Guys just want report back. Yesterday I reboot my system completely formated all harddisk and reinstall windows 7, Edius 8 and Vistitle 2.6 but still get the same error message DynaTexture can't be read. Please see attach.
                                I don't think there were installation mistake with windows or Edius, the problem is the actual Vistile, I don't know exactly why Dynatextur can't be open everything else works well. Having already sent message to Vistitle support but they but don't responded yet.
                                MICHAEL
                                EDIUS 8.1
