Hello guys need your help
    Originally posted by GrassValley_PS View Post
    After you try Jerry's question, Can you find it in Windows Explorer and try dragging from there.
    this is really omplicated where and how in windows explorer should I do this, can you explain a little.
    MICHAEL
    EDIUS 8.1
    Operativsystem win7 pro 64-biter: Motherboard X79 extreme 11: Processor Intel Core i7-3930K 3.5Ghz: Ram 32GB DDR3,2133MHZ: Graphiccard Nvidia GTX 680 4GB PhysX CUDA: MAIN drive Samsung 840 PRO SSD RAID 476 GB: SECOND driver WD RAID0 1.81 TB:
    THIRD drive workstation G-Driver 12 TB external plugin USB 3: HDSpark monitor TV 32 inches: Blu-ray burner Asus 12x BD-R 8MB Sata: SONY camera A7S2 & A99 DSLR.
    http://www.nett-one.com
      What OS and version of Edius?
      Do you happen to have Windows updates set to automatically update?
      If so, was anything updated prior to this issue?
      Did you install any 3rd party software prior to this issue?
      Just trying to cover the bases.
        1. Windows 7 64 bit new pc clear installed
        2. Edius version 8.1
        3. Yes windows updates is set automatically
        4. No did not installed 3rd part software
        MICHAEL
        EDIUS 8.1
          ftp://ftp.cis-app.com/pub/hasp/Senti....9_Windows.zip
          Download this dongle driver and install it. After installation, reboot. See if that helps.
          One of the updates in Windows updater could have put a whammy on Vistitle.
          Don't know. I don't know if the driver update will help or not.
          After this I'm going to recommend you PM VX Chen. I'm sure he will have a few Ideas.
            I did install the driver and reboot my pc, but still the same message file can't be read.
            MICHAEL
            EDIUS 8.1
            • #21
              It is really very simple. Go to C:\ProgramData\Vexel\VisTitle\Library\SysLib\DynaT exture\DynaTexture1 and see if you can drag and drop one of those files into the Bin.
              • #22
                Send a pm to VX Chen and get his ideas.
                • #23
                  Also, don't discount the option to uninstall both Vistitle and Edius 8.1 and re-install both as a possible fix.
                  • #24
                    I did already uninstall Vistile still nothing news. I don't think the problem is with Edius but actual is with the vistile. I have already sent PM message to chi as you said.
                    MICHAEL
                    EDIUS 8.1
                    • #25
                      can you confirm that quicktime player is installed and that you can place regular jpg images on the timeline?
                      maybe vistitle needs qt player for handling dyna textures?
                      • #26
                        Hello Anton yes quicktime is installed latest v7.7.8 and I have no problem with other regular images I can to edit and drop on the timeline works perfert. My problem is only with the animated dyna Texture template.
                        MICHAEL
                        EDIUS 8.1
                        • #27
                          I remember this issue from some time ago but can't remember the solution
                          from memory, it had to do with wrong storage location
                          send support email to vistitle, you should have a fast solution
                          • #28
                            I believe so there is samthing wrong with the storage location. Yesterday I checking folder where the VisTitle\Library\SysLib\DynaT exture is located but the folder is not there i can't see it. Please see my attach.image.
                            I have already sent pm message to VX Chen on this forum here but they not responded yet.
                            MICHAEL
                            EDIUS 8.1
                            • #29
                              the correct location is C:\ProgramData\Vexel\VisTitle\Library\SysLib\DynaT exture
                              • #30
                                Well this is really bad and very stanger the program installed added folder automatically for me, did not selected or change any folder path when I installed. which folder should I choice then to install Vistitle, please attch.
                                MICHAEL
                                EDIUS 8.1
