Hello guys need your help
  • Hello guys need your help
    Trying to use DynaTexture animated template from Edius vistle library template, I drap template to Edius timeline or bin folder get error message the file could not open. Please see image attach. Thank you.
    MICHAEL
    EDIUS 8.1
    Operativsystem win7 pro 64-biter: Motherboard X79 extreme 11: Processor Intel Core i7-3930K 3.5Ghz: Ram 32GB DDR3,2133MHZ: Graphiccard Nvidia GTX 680 4GB PhysX CUDA: MAIN drive Samsung 840 PRO SSD RAID 476 GB: SECOND driver WD RAID0 1.81 TB:
    THIRD drive workstation G-Driver 12 TB external plugin USB 3: HDSpark monitor TV 32 inches: Blu-ray burner Asus 12x BD-R 8MB Sata: SONY camera A7S2 & A99 DSLR.
    http://www.nett-one.com
    It works fine here. What version of Vistitle are you using?
      I'm using version 2.6 with Edius 8.1
      MICHAEL
      EDIUS 8.1
        I have that exact combination. Maybe Jerry can help.
          Thank you, hope then Jerry can help on this.. do you think he is online now ??
          MICHAEL
          EDIUS 8.1
            I would uninstall Vistitle>reboot>install and reboot. Then download Directx from here and run: https://www.microsoft.com/en-us/down...s.aspx?id=7087 then reboot again.
            Try this and see if that fixes it.
              Thanks Jerry I will do that and let you know what happen.
              MICHAEL
              EDIUS 8.1
                Hi Jerry you know what this is really very strange, I did exactly as you described but still nothing happen. I got the same error message file could not open.
                MICHAEL
                EDIUS 8.1
                  Have you tried any other clips from the template or only that one?
                    Start a new Vistitle title and try to apply a Dyna texture to a shape. Does it work in Vistitle?
                      There are no problems start Vistitle, the problem is only with animated Dyna temples.
                      MICHAEL
                      EDIUS 8.1
                        Yes I have treid with whole template, all can not be opened.
                        MICHAEL
                        EDIUS 8.1
                          Are you saying that Vistitle won't open? Do you have an anti virus running?
                            After you try Jerry's question, Can you find it in Windows Explorer and try dragging from there.
                              No I'm saying don't have trouble to start up Vistitel, my problem is only with Dyna Texture template can't drap to timeline or bin folder. There is no antivirus installed PC.
                              MICHAEL
                              EDIUS 8.1
