Importing saved picture into Vistitle?
  • Importing saved picture into Vistitle?
    I have Vistitle 2.6.
    I want to add 5 stars to a review in a title. I used the star character object in Vistitle then copied and pasted 5 in a row, grouped these and resized it. Then I saved as a picture to be able to bring it into other titles.
    I am not sure I have made this in the best way, but although I can import the image back into Vistitle, how can I do this easily so that the image is the same size as the original?
    At the moment I have to draw a box to import the image but this seems a bit hit and miss to get the correct scale.
    For the moment I have just gone back into the original title and copied and pasted to the new one...but there must be a better way...isnt there?
    Hi John, when you saved it did you try to import it back into the library through the Image section?
    I created a Vistitle project with 5 stars and saved it as a .tga.
    I then imported the .tga into the Image section within the Library.
    After that, I just applied it to the Edit Screen.
    Try the method in the video.
    image import.mp4
      Thank you Jerry, that is exactly what I wanted to do.
      Where I was going wrong was going to the toolbar and selecting Object/Image, not importing it into the library as you have shown me.
