When I use the Stand ALone version (SAL) there is an option "Keep camera dynamics". Unticking this means that the clip will be treated as being shot from a tripot. The result is a very stable clip.
In the plugin I cannot find this option.
Where did it go, is it still there?
Is it a problem if you want your shots to look like being shot using a tripot? Or should I say: does it matter, is the end result still the same?
Chris
Chris
