Newblue titlepro 4
  • Newblue titlepro 4
    When I want to change the duration of my title (titlepro4) I got to restart edius
    And often my title disappear
    Is it a bug ?
    PC PRINCIPAL: intensificateur 4k pro - edius X- maximus heroX wifi - processeur Intel I7 8700K; mémoire 16 Go SKILL - xpredator2 - corsair 650W HX
    this is being widely reported to Newblue
    not sure if Newblue or EDIUS problem, but the two don't get on well
      Well I think I'll hold off purchasing the upgrade then :)
      Software:
      Edius 8.5 Workgroup
      NewBlue FX
      Hitfilm Ignite
      Vitascene 2
      Newblue TitleMotion Pro
      Smartsound 5.8
      Desktop:
      MSI Z170A M5 Motherboard, i7 6700K 4Ghz, 32GB DDR4, NVIDIA 970 4Gb, 240GB Boot SDD, 500Gb Video SSD, Windows 10 Pro 64bit
      Laptop:
      MSI GS60, 4K UHD, Intel i7, 16Gb DDR3, Nvidia 970M 3Gb, Windows 10 64bit
      Cameras:
      Panasonic HC-VX870 4K
      GoPro Hero4 Black
      Panasonic GX8 (Stills & Video)
      Garmin Virb 360
        I would email Newblue and ask how to avoid the offline appearance of titles after restart
        It usually does not happen if the duration is set correct before adding the title, this can be done by enabling the EDIUS option to add stills between in and out, that way you can mark in and out where the title needs to start and end, then right click a V track between in and out and add the Newblue title
          How are you changing the duration? Are you using elastic mode? Edius 7.5 or Edius 8? TP4 has some problems but I can extend the timeline with in the TP4 interface and then extend the clip on the Edius timeline without issue.
          This is with edius 7.5 and TP4 150904
          I can also reboot and not loose the title on the Edius timeline. TP4 can sometimes open and you won't see the title, but clicking the timeline brings it back.
          Contact New Blue and tell them all of the 3rd party plugins that you have installed on your system. That is any plugin or AE bridge item either certified by GV or not.
            Also check that there is no fade in or out on the title as this is now set as a default buy NB
            If your cursor is at start you wont see it untill you scrub
              Thanks for the info. Just about to purchase. Will wait...
              Dano
