Edius WG8 Isotope filters
  • Edius WG8 Isotope filters
    I cant seem to find the isotope audio filters in Edius WG8. Am i missing something?
    Thanks in advance,
    Dano
    There are no free ones, if that is what you are asking.
      Not at all looking for free ones. Had the isotope filters in edius 6.08. Lost them when I upgraded to edius 8 wg.
      Was that supposed to happen. Or do they no longer work with 8wg
      Dano
        EDIUS 8 is 64 bit EDIUS 6 32.
        Install the correct version (64 bit) of your plugs and link EDIUS to the correct folder.
          You may be looking at a cost to upgrade to 64bit plugins. Check for upgrade pricing at Izotope. The exact plugin may not be offered any longer.
            I have not tried this myself, but there is a method (apparantly) to use 32bit VSTs in a 64bit program.
            It has a free demo, but the software is only $14.99.
            https://jstuff.wordpress.com/jbridge/
              In Edius 6 you got free Izoptope plug-ins. These were not available in 6.5 onwards.
                Got it fixed. Thanks to all...
                Dano
                  How did you get it fixed?
                    Forgot to point edius to the izoptope folder....
