grain reducing filter
  • grain reducing filter
    ok before I deliver it I need to take a shot in the dark here. I had a shooter screw up with one of my cameras and shot 1/3 of a video with JVCs "LO LUX" mode which should never be put on the outside buttons if you ask me its awefull. is there a filter that can reduce this hidous video noise I now have?
    Randy
    Have you tried Neat Video?
      trying it now, its rendering some of it. unless im doing something wrong it doesnt seem to be doind anything. Its a demo.
      Randy
        http://www-en.ediusworld.com/edifica...eo-and-edius-7
          You have to place the Neat filter above layouter in filter order and set up the sample area for optimum performance. Works really well but is time consuming if you have a long clip. It will change by scene too so you may not want to apply to the whole camera file in one go.
          Ron Evans
          Ron Evans
            Did you use NeatVideo 4.0 ??
            That works fine!
            kurt
            Intel core i7-6700K / ASUS Z170A / 32 GB RAM / Intel HD Graphics 530 / SSD Systemdrive / Gigabyte GeForce GT 1070 / Win-10/64 Pro / EdiusX-WG (10.20)/ Mercalli (V2, V4 and V5 Plugin/64bit) / Resolve-17.3.00014 Studio / ImgBurn / PowerDVD etc.
            // Read > Test > Understand
              I am using 4.0 and I followed the tutorial but I dont see a difference. Thanks anyway i'll just deliver it and may have to return some money:(
              Randy
              Randy
                Neat video 4 gives very good results and is working for me. Maybe it is the demo?
                  works fine here also
                  if the video does not have much movement, you can also try the EDIUS motion blur filter at around 30-40%, it should reduce grain drastically
                    So far Neat video has always gotten me out of tight spots.
                    If no to little movement you can push it very far but tend to look plasticky if overdone.
                    Take your time to look for a good spot in your source to create a good clean noise profile, it's worth the effort.
                    Tony D.
                      If the source footage is too far gone i intend to make 1 video layer with extremely cleaned up version of that and blend it with the original bad source on another v track to get rid of the 'plastic' look and make it more organic.
                      It doesn't always work but give it a try.
                      Still using version 3.x btw
                      Tony D.
                        Where does the rendering take place?The plug-in doesnt seem to do anything
                        Randy
                          The tutorial clearly shows it. :)
                          When you are done with your settings in the plug you apply and exit and render.
                          Note: When the plug is correctly applied you will see the results immediately in the preview of neat video.
                            you know what maybe it is working its just hard to tell with the demo box in the middle
                            Randy
                              Believe me if you are thinking of giving money back to your client it is better to purchase Neat Video. (invest)
