VST error
  • VST error
    odd one,
    I've been using Wavearts for ages 64 bit VST plugin in Edius 7.5 191. Started up my current project today - I get a Edius VST host has stopped working - shortly after project opens.
    Done all the usual things - re installed WaveArts, tried a fresh project, blah blah, simply cannot get to where I was yesterday with a stable set up.
    The system is not attached to the internet either.
    Spooky
    Paul :-)
    is the path to the VST still in EDIUS system settings?
    if yes, is the VST file still in that location?
      yes and yes - everything appears OK, but the Ediusvst error report says the .dll relating to the plugin has unloaded..
      Paul:-)
      I'm also getting a bex error on exit from Looks 3 - just a boring side issue !!
        unless your profile corrupted? can you make a new one in system settings, then restart EDIUS and select the new one
        then set the path to the VST and see if it works
        if yes, you will have to redo all your button customizations etc. again :(
          nope, I re installed Edius, and tried a new profile - same problem...
          Paul -)
            Just in case this helps anyone - I downloaded the newer Wavearts update of Powersuite 5, which when installed, needs you to re register your serial number - attempting this in edius causes a total crash and exit.
            I re-registered the plugin using Vegas, worked fine, now all is well again with Edius too.
            It appears Edius has some quirk with the registration process, as when you open the dialogue to input your machine ID etc, the entire system locks up.
            Paul :-)
            Mods, maybe move this thread to third party where it really belongs?
              Done. :) Thanks for posting the solution.
