Problems with Quicksync & TMPG AVC Plugin
  • Problems with Quicksync & TMPG AVC Plugin
    I recently purchased the AVC encoder plugin from TMPG and am having issues with Quicksync. I am still running Edius 7.5 on Windows 7 and have realized I have lost Quicksync in general with the Edius encoder.
    When I use the AVC plugin Quicksync works but the encode stalls at different parts of the file. The timer still counts but the progress bar fails to go on.
    Uninstalled the AVC plugin, yet QS still does not work. I have tried older drivers and now have the newest drivers.
    What to do? Can't go to Edius 8 as the plugin is for v7.
    Is there some magical Quicksync driver that actually works??? Of course I have a job to deliver... Am exporting uncompressed to encode in Handbrake but lost a day in the mess.
    Thanks for your input.
    Is your on-board video connected to a monitor? You don't have to use it, but it should be plugged into a second input on a monitor so that the on-board video isn't shut off.
      Yes, I should mention that I have had Quicksync working in the past.
        Before installing Edius 8 first make a copy from the Edius 7 plugin folder of the TMPGEncLibraryAVC folder and the file TMPGEncE7AVC.tpi then after installing Edius 8 paste these to the Edius 8 plugin folder.
        That's what I did, works just fine.
        Claire
          Tim, was the temp folder cleared and the anti-virus turned off prior to installation?
            Hey Jerry,
            No, but what installation - AVC plugin or new Intel drivers? Because QS is not working using the Edius internal encoder either.
            I use Microsoft SE.
            And, does the AVC plugin work with Edius 8? If so I might just switch.
              What changed from the last time you had QS working?
                I don't know. I have not used it in a while but I now remember realizing it was not working a few months back.
                What is odd is that QS is working inside the AVC plugin, it just stalls during the encode.
                  Back off the OC and see if that makes a difference.
                    I did that as well :) That is what started all of this. I tried a non-QS encode of an hour and a half football game in 1080p60... It stop-errored sometime in the night.
                      What do you think, should I just move to Edius 8? I was waiting for Windows 10 but I can wait longer for Windows 10.
                      Just to make sure, the plugin works with Edius 8?
                        Look at the event log and see if it gives any details.
                        What driver version are you using?
                          I do not know what I am looking at inside the event log...:)
                          I have the very latest QS driver updated using the Intel update tool.
                            That is the problem.
                            Try this driver For Windows 7 64.
                            https://drive.google.com/file/d/0B78...ew?usp=sharing
                            If you're using Windows 10 you need to use driver 10.18.10.4252.
                            If the driver keeps getting changed by Windows update download this handy tool to fix that:
                            http://download.microsoft.com/downlo...owhide.diagcab
                              Thanks Jerry. You are genius. Works fine again after installing your driver.
                              How do you know which driver works? Just trial and error testing?
                              And what is up with these Quicksync drivers? They are broken as often as they work.
